Upcoming Versions of Zorin OS Pro
Do you need to pay again for future versions of Zorin OS Pro?
Your purchase of Zorin OS Pro will give you access to future updates within the current version series. For example, if you purchased Zorin OS 18 Pro, you’ll get access to future point releases of it as well.
Upcoming major versions – such as Zorin OS 19 Pro – will need to be purchased separately after they are released in the future. However, you’ll be able to upgrade to future major versions at a discount.
We will continue to support Zorin OS 18 with software updates until at least June 2029, and you will be able to download and use your purchased copy of Zorin OS Pro for life.
Download Zorin OS Pro
