When Will Zorin OS 17 Be released?
We're tentatively planning to launch Zorin OS 17 in the 2nd half of 2023.
We release major new versions of Zorin OS roughly every 2 years and are tentatively planning to launch Zorin OS 17 in the 2nd half of 2023. However, we follow a “release when ready” policy, so we don’t have an exact date set for the launch. This time frame is subject to change based on development progress.
If you wish to be the first to know when Zorin OS 17 will be available to use, you can subscribe to our newsletter.
Subscribe to the Zorin Newsletter ›
In the meantime, we recommend that you use Zorin OS 16, which will be supported with software updates and security patches until April 2025. You will also be able to directly upgrade from Zorin OS 16 to 17 shortly after its release.
