1 minute read
Verify if You're Running Zorin OS Pro
How to check whether you've installed Zorin OS Pro onto your computer.
On this page
1 minute read
System information
To check if you have installed Zorin OS Pro, please open the Zorin Menu → Settings → About and check the “OS Name” field.
All desktop layouts
- Open the Zorin Menu → Zorin Appearance.
 - If all the desktop layouts are available in the “Layouts” section, this means that you’re running Zorin OS Pro.
- In Zorin OS Pro you should see all 10 desktop layouts instead of 4 layouts in the Core edition.
 - In Zorin OS Pro Lite you should see all 6 desktop layouts instead of 2 layouts in the standard Lite edition.
Additional Creative Suite and Advanced Productivity apps
If you’re running Zorin OS Pro, you should also notice many more creativity and productivity apps. You can find them in the Graphics, Sound & Video, and Office categories of the Zorin Menu.
If you can’t find the additional creative suite and productivity apps, you may have selected the “Minimal Install” option while installing Zorin OS.
